Alright we installed a supercharger on a 2002 Mustang Gt. Procharger (8psi).
Well the sounds start upon initial startup. The head unit area sounds like it is spinning dry (but it has the oil in it)...
The belt is to loose and has a bit to much play in it. It seems the idler pulley is to loose because we can push it with our fingers in and out a bit.
He had a squeeky belt problem before the supercharger install...related?
Also after the car is revved (2000rpm) and the engine comes down on the revs the supercharger unit gives off a turbo blow off sound...but it shouldn't right?
The car also won't idle without giving it a bit of gas...and it is slow to rev...
Any thoughts
Thanks
He had a squeeky belt problem before the supercharger install...related?Also after the car is revved (2000rpm) and the engine comes down on the revs the supercharger unit gives off a turbo blow off sound...but it shouldn't right?
Any thoughts
Thanks
