HELP rear seat removal
Marks89GT
128
Dudley MA
I have an 89 gt hatch and im dying my interior vinyl parts and im trying to remove the rear seats and im completely lost. all the rear seat delete tutorials just say remove the rear seats. some say to remove the 4 bolts in the center but i can barely fit my finger down there let alone a ratchet. there has to be an easier way. in every car ive ever worked on theres some hidden lever or something. maybe im wrong but i need some help.... thanks in advance.
IIRC you can pull the seats down towards the front of the car and unbolt the four bolts attaching the seat back to the folding mounts (they are located on the far left and right sides, you may have to pull back the hatch carpet to be able to see them.) If this is incorrect I'm sorry I've had mine apart for more than a year so its a little fuzzy.
Yeah, you need to remove the hatch carpet first. If my memory serves once you do that you'll see what needs to get unbolted. It's a pretty easy process once you see what you need to unscrew and unbolt.
remove the rear hatch carpet, then you will have to unbolt the release levers from the seat backs by tilting the seats forward a litttle to gain access. then you can unbolt the rear metal hinge plate from the rear hatch area floor. the lower cusion I will assume you got out but just in case it just clips in. you have to push in/pull up at its base to release it. the seat backs are held in by 2 middle nuts and 2 bolts on either side that can be a pia to reinstall and to slide those washers back in.
