  • SN95 4.6L Mustang Tech
HELP! Reverse Idler in TR3650
  • Thread starter Thread starter Smokeurhonda
  • Start date Start date Feb 17, 2007
Smokeurhonda
457
Maryland
Feb 17, 2007
  • Feb 17, 2007
Originally I took my trans out to replace a 4th gear synchro assemble due to a grind under hard shifting. I ended up replaceing 1-2 synchro 3-4 synchro, and 3 and 4 sychro rings. When reinstalled the trans had a binding feeling when rolling to a stop in neutral, could hear in the rear of the car. Also had the same binding in reverse when moving right as i pushed the clutch in. Except the noise could be heard in the firewall area. Also had increased shifting effort in all gears. It is NOT a clutch related issue.
I took out the trans a second time, the only thing I could find that was wrong is countershaft endplay is .002" to large out of spec. I also found that the reverse idler has an ample amount of play in it, probably .100" or so.
My questions are. Can anybody think what could be causeing this problem? Also does anybody know how much play is suppose to be in the reverse idler gear? Please help.
blackink00
I missed a shift & stole Curt's money.
Mar 30, 2005
545
Tempe, AZ
Feb 17, 2007
  • Feb 17, 2007
the reverse gear should have only like.005 endplay on it. as far as the hard shifting the blocker rings could be bent.
Smokeurhonda
457
Maryland
Feb 18, 2007
  • Feb 18, 2007
Not the reverse gear, but the reverse idler. Does your spec still aplly?
Smokeurhonda
457
Maryland
Feb 19, 2007
  • Feb 19, 2007
Anybody?
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Front window issues
  • bruno
  • Saturday at 2:16 PM
Fox 5.0 Mustang Tech Monday at 8:13 PM
AeroCoupe
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
