Help Setting Up Roller Rockers
  • Thread starter Thread starter justin91lx
  • Start date Start date Aug 24, 2014
justin91lx
18
Texas
Aug 24, 2014
  • Aug 24, 2014
I'm im the middle of getting this motor together and im not sure im doing the rockers right. Im running trickflow 1.6 Stud mouted rockers. I got the lash out and then turn the rocker arm adjusting nut 3/4 and locked it down. Going by the trickflow says. I noticed half of my adjusting nuts weren't even that okay?
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 24, 2014
  • Aug 24, 2014
See this as a start....
http://www.stangnet.com/mustang-for...-other-stud-pedestal-mount-roller-rockers.28/
They shouldn't' take more than 1/2-3/4 of a turn to lock them down. Check the position of the roller tip on the valve stem to ensure than the tip is making contact with the centre.
95BlueStallion
My assy trans to myself
5,130
3,103
214
Cedar Rapids, Iowa
Aug 24, 2014
  • Aug 24, 2014
Are you rotating the engine?
justin91lx
18
Texas
Aug 24, 2014
  • Aug 24, 2014
The tip is smack center of the valve stem.
justin91lx
18
Texas
Aug 24, 2014
  • Aug 24, 2014
Yes and did them all in the firing order
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 24, 2014
  • Aug 24, 2014
After you've adjusted the rockers, let it sit 20-min or so and do each rocker again. The rockers maybe be pumped up with oil and can often lift the valve as opposed to depress the plunger in the lifter.
Shoot for between .020-.030 preload on each lifter. From what I've seen, keeping them at the shallow end of the acceptable range keeps them the quietest.
madspeed
Colonel Mustard
1,332
204
a van down by the river
Aug 24, 2014
  • Aug 24, 2014
lifters were likely bled down
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 24, 2014
  • Aug 24, 2014
Yeah, that was kinda my point for letting it sit for a bit before doing it again.
I lucked out when I did my last set up and started with brand new lifters.
justin91lx
18
Texas
Aug 24, 2014
  • Aug 24, 2014
Think that's where I went wrong. I didn't let it sit. I'm also running new ford racing high performance lifter.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 24, 2014
#10
  • Aug 24, 2014
  • #10
If they're new, then they shouldn't need to sit, as they have never been pumped up with oil. You should be able to feel the plunger depressing slightly when you preload it?
justin91lx
18
Texas
Aug 25, 2014
#11
  • Aug 25, 2014
  • #11
They do depress with slight load. I did have them soak in oil for a week if that makes a difference.
Gearbanger 101
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Aug 25, 2014
#12
  • Aug 25, 2014
  • #12
Soaking them in oil won't really do much but lubricate the outside of the lifter. In order to "pump them up" you'll need to run them and have the oil pump prime them.
I would set them up before hand.
Be warned though, if this is the first time starting the engine with new lifters and you haven't pre primed the oil pump, it's gonna make a heck of a racket. That's normal. It should clear up within a minute.
justin91lx
18
Texas
Aug 26, 2014
#13
  • Aug 26, 2014
  • #13
Yeah its a new motor. My first motor to build. Been a big learning curve. Just hope she starts and don't blow up.
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
D
Rockers, lash adjusters and timing: help with parts (4.6 2v)
  • dvigAtel
  • Nov 1, 2025
  • Other Auto Tech
Other Auto Tech Nov 1, 2025
dvigAtel
D
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
