Help!! Starting issue
  • Thread starter Thread starter xtreme02stang
  • Start date Start date Jan 6, 2010
xtreme02stang
23
Orlando
Jan 6, 2010
  • Jan 6, 2010
I have a 93gt that has a crank no start issue. If i turn the key to start the motor will just turn over, but when i let the key go it will start. It will also start right away if i jump the solenoid on the fender with the key in run. I have already replaced the ignition switch and plug for it. Any ideas? I'm stuck.....
HISSIN50
34
129
Jan 6, 2010
  • Jan 6, 2010
Going back to your other thread about this, did you ever test the solenoid itself? Jumping the big solenoid lugs like you did will bypass the solenoid. The other test utilizes the solenoid to see if it's the issue.
xtreme02stang
23
Orlando
Jan 10, 2010
  • Jan 10, 2010
Well, I just ran some tests from the "crank/no start" check list on here and came up with nothing. I tested the solenoid by taking the push on wire off and jumping that stud with the power side of the solenoid and I have spark all the way to the plugs. I have power at the injectors when the key in the run position but don't have a noid light to check it while in the crank position. Any ideas would be awesome. Thank you.
HISSIN50
34
129
Jan 10, 2010
  • Jan 10, 2010
If the car doesn't crank, fix that first. Your battery might be discharged, etc.
Then run the checklist from top to bottom. Don't skip steps and you'll find the issue.
xtreme02stang
23
Orlando
Jan 10, 2010
  • Jan 10, 2010
Cranking isnt the issue, it cranks fine, just wont fire in the crank position, only starts up when you let go off the key after cranking.
HISSIN50
34
129
Jan 11, 2010
  • Jan 11, 2010
So you have spark while it cranks but will not catch? If so, the TFI should be receiving the start input from the ignition switch. What color was the spark?
The solenoid trigger is receiving a solid 12.0+ V cranking signal? It might not be based upon how you're jumping the solenoid and what is happening. If the crank signal is compromised and the voltage in the circuit is down, that could be why the solenoid is acting up. It could also lead to a weak spark.
xtreme02stang
23
Orlando
Mar 7, 2010
  • Mar 7, 2010
Well, I finally got back around to looking into my issue. It's not my daily driver so i wasnt in a hurry to fix it. The car sat for about a month and when i went to start it the other day i noticed the fuel pump didnt come on when i turned the key on. So to make a long story short the pcm needed to be replaced to fix the fuel pump not coming on and my previous issue of not starting when i turn the key(only started when i let go of the key after cranking) Ended up killing two birds with one stone. I opened up the old pcm and found 2 capacitors burnt up. Learn something new every time. Thanks for your help with the issue.
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
D
Electrical Weird door wiring issues
  • Dakar09
  • Oct 20, 2026
Dakar09
D
9
1997 gt Starts then dies a few seconds after.
  • 97orange
  • Aug 13, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 17, 2026
97orange
9
A
1987 5.0 speed density Foxbody crank no start
  • Alan2204
  • May 23, 2026
Fox 5.0 Mustang Tech May 30, 2026
Mcmahst
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
