M Mega1989 New Member Dec 8, 2003 2 0 0 Dec 8, 2003 #1 Dec 8, 2003 #1 I need help! Im trying to install a timing chain on a 2000 GT 4.6 Can someone please give a step by step or some direction? I really appreciate it! thanks
joker12552 Founding Member Oct 23, 2001 569 0 0 Birmingham, AL Dec 8, 2003 #2 Dec 8, 2003 #2 Check out these two links. Together, they should pretty much give you a step in the right direction This one just tells how to time the engine http://phatdoggy.home.comcast.net/sohc_timing.htm This one is instructions on a 4.6 cam swap, whcih should include some info as far as removing and replacing the timing chain. Although it's for 96 to 98 cars, it is the same for yours. http://www.modulardepot.com/?show=articlesdet&aid=12
M Mega1989 New Member Dec 8, 2003 2 0 0 Dec 8, 2003 #3 Dec 8, 2003 #3 Thanks Alot!!! Hey Joker! Thanks alot! You where a great help. I put the info together and got a solution. thanks again pal! Mega
