ok I just took off the little plate connected to the trans that allows you to see the TO bearing and clutch. When I took off that plate, a few pieces of my flywheel were in there, like 3-4 pea sized pieces. Does this mean that my clutch and/or flywheel is the problem and not the transmission?
If the flywheel is screwed up, will the car not shift into any gears?
In a previous thread, I posted how I couldn't shift into any gears after getting on it a little. With the clutch engaged, the shifter wouldn't go into any gear.
I do have 410 rwhp, so I thought the trans went because it couldn't handle the power. However, I do have a centerforce DF clutch and it should handle this power. Any ideas what the heck is wrong?
