HELP!! Two questions about leaking BBK Headers
I have an 86 GT, BBK shorty headers. I cannot get them to quit leaking at the collectors! I have the nuts tightened as tight as I can get them, and I'm afraid to go more without breaking off the stud. (By the way, I posted in another thread trying to find the right sized nut, 7/16 was too small, 1/2 was just a tad too big, so I had to use a 12mm...why would BBK use metric? Perhaps someone changed the studs, who knows...anyway)
I can feel exhaust blowing by ever so slightly at the collector. Nothing is cracked or bent. I was thinking I'll loosen the nuts up and push up on the H-pipe with a jack and then retighten so I'm not trying to pull the pipe up just by tightening the nuts...anyone have any thoughts on this?
#2: Anyone have any tips or tricks on how to tighten the header bolts up top? I think mine are tight, but I can't hear if there any leaks up there because the collector is so loud. I can't get a wrench in there, and no combination of swivel or wobble extension will work. How did you guys make sure your heads are tight? How can you even get in there?
Thanks!
make sure the h-pipe is pushed far enough foward. it should fit well. ive never had problems with bbk headers. i have a set in my garage ill go check the nut size if you'd like.
Yea, if you could do that, that would be great. So you think I should just simply unbolt the H-pipe in the back and tighten up the collectors some more?
I bought these headers from Ebay, and I just assumed they used the same size nut as the factory pieces. I didn't even think to check.
BBK's shorties are a little wide at the collectors. Equal lengths are about an inch wider than stock. I used a piece of wood to pry the H apart and bolted it down evenly so i fit in the cup. I have a set of headers that the ball collector got bent up pretty good so be careful.
Kevin
