  • SN95 4.6L Mustang Tech
Help w/ throttle sensor
  • Thread starter Thread starter PacificStang46
  • Start date Start date Apr 15, 2004
PacificStang46
73
In Your Blind Spot!
Apr 15, 2004
  • Apr 15, 2004
I recently bought a BBK 75mm throttle body and p/p plenum.....I had the codes read to see if anything came up besides no cats, well code 122 did, said something about throttle/pedal sensor having low input! well what the hell does that mean and how do I fix it? please help!
J
JimC
170
Duluth GA
Apr 15, 2004
  • Apr 15, 2004
My wild ass guess is when you swapped the TBS to your new throttle body it's picking up a low voltage signal. You can adjust TBS voltage by loosening the TBS screw and moving it slightly. Put a volt meter on it to make sure your moving it in the right direction.
PacificStang46
73
In Your Blind Spot!
Apr 15, 2004
  • Apr 15, 2004
How much is enough voltage? alos I was told to put my stock TBS back on and try it!
GT2000JAY
1,344
Northwest
Apr 15, 2004
  • Apr 15, 2004
I got that code when I did my plenum swap, too. I used a digital voltmeter to check the voltage on the Throttle Positions Sensor - positive lead to the middle wire on the TPS, ground to a bolt/rivet on the strut tower. The voltage should be around .98-.99V when the throttle body is at rest.
Mine was around .80V when I got the code. Like was said above, try loosening the TPS screws and moving it a bit until you get the right reading then tighten it back up. I actually had to use a drill and enlarge the holes a bit to get it to read right. No problem since.
Jay
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Tuesday at 10:14 PM
DangStitches
D
  • Gulftown980x
  • Jul 29, 2026
squeak93
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
F
Trouble Shooting Sudden Shift of AFR at low RPM
  • Farva_84
  • Jun 6, 2025
SN95 4.6L Mustang Tech Jun 8, 2025
Farva_84
F
