Help w/ throttle sensor
I recently bought a BBK 75mm throttle body and p/p plenum.....I had the codes read to see if anything came up besides no cats, well code 122 did, said something about throttle/pedal sensor having low input! well what the hell does that mean and how do I fix it? please help! :shrug:
My wild ass guess :shrug: is when you swapped the TBS to your new throttle body it's picking up a low voltage signal. You can adjust TBS voltage by loosening the TBS screw and moving it slightly. Put a volt meter on it to make sure your moving it in the right direction.
I got that code when I did my plenum swap, too. I used a digital voltmeter to check the voltage on the Throttle Positions Sensor - positive lead to the middle wire on the TPS, ground to a bolt/rivet on the strut tower. The voltage should be around .98-.99V when the throttle body is at rest.
Mine was around .80V when I got the code. Like was said above, try loosening the TPS screws and moving it a bit until you get the right reading then tighten it back up. I actually had to use a drill and enlarge the holes a bit to get it to read right. No problem since.
Jay
