HELP! water leak front floorboards
abbiesweet
Lebanon TN
Hiiii.
For a few weeks there has been quite a bit of water to drip into the front floorboards. A few days ago my bf noticed that its now causing electrical issues & overheated on the interstate yesterday, he pulled over let it sit for over an hour & was able to make it back home(he said he sat with the air on high for probably 20/30 minutes before it happened & felt that might be why). He wants to clean out & drain the water from underneath the cowel but he cant seem to find where the plugs or drain is located. I have searched EVERYWHERE online & cant find any videos or pictures showing their location on 99-04 models.. Any advice would be appreciated!
There really isn't a drain for the front cowl area. Most likely the reason is the windshield is sealed poorly, or the seal is failing at the base and water running down the edges is seeping in. If it's causing issues with the wiring this is likely the case if it's dripping at the corners on all the wiring in the kick panel.
Would need more specifics to really offer any assistance but my lead suspicion would be a poorly sealed windshield, especially if it's been replaced at some point.
Usually it doesn't start leaking into the floorboards until we make a turn so its pooling up somewhere, is there a spot we could maybe drill a hole to get all the water out before resealing the windshield?
we also replaced the relay box because it was full of water
Pass side? Drivers side? Both? Which relay box? Kinda need a little more info as to what you are seeing in terms of what is getting wet in the car.
You can try pulling the cowl panel off. Then you can use a cup of water and pour it in and go for a drive and see if you can ID where the leak is. I wouldn’t try to reseal the windshield yet.
It's the A/C evap box that is leaking.
Look under the hood for the A/C drain hole on the passenger side next to the transmission tunnel. Should be a rubber nipple. Carefully (so as not to poke a hole in the evap coil) poke something into that hole and clear out any debris.
It might be easier to find/spot once the A/C has been run for bit.
