help!! what mod should i do next CAMS??
quickndslick2
Banned
Sep 28, 2009
24
i have a 2002 gt with CAI, 70mm TB and PLENUM, bbk LT, o/r X pipe, and magnaflow exhaust, steeda UDP, and diablosport predator tuner (93 octane tune for now) i was wondering what mod should i get next without having to go with turbo or sc or n02, since the car is a daily driver and i do driver alot plus i want it to be reliable, i was thinkin about getting comp cams stage 2 and the comp cam gears also? what do you guys think? is it worth it? would it really make a diffrence? if i do so i will get the car dyno tuned with a custome tune aftwards, im just wonder if its worth spending the money??
and i cant do heads for not so will the stock ones be fine?? also the valve springs will the stock ones be fine? please help me out in anyways want to get this done asap
thanks in advance
Had most of the Mods you do before putting in 4.10s man what a differance. Also the Diablo 93 performance tune left a lot on the table and caused a slightly lean condition (not as lean as stock). The Dyno tune neted me 19 HP and 5TQ over the performance tune. If getting the cam than wait on that. My next mod is Hooker LTs siting in my Gerage.
+1 on the gears. Suspension mods (shocks, struts, springs etc) shifter, port/polish head and intake. Also, I would have to ask what you want to do to the car in the future. For example, are you sure you don't have any plans to add induction? Is a stroker kit out of the question?
