Help.. who has a solar wing???
Ive tried all day mounting this thing... first i used 3M double sided tape... it came right off... then i tried silicone right to thew glass.... cam right off and left a mess.... whats a good way to mount this where i KNOW its not goin anywhere???
well man your best bet is to clean the window with alcohol and use 3 m tape again and then a heat gun on it after you put it on, and if that dont work heat the window with a heat gun and make sure you get it nice and hot and then put it on and press it down on there and then run the heat gun across and it will never come off and JUST USE 3M TAPE DONT USE ANYTHING ELES
