Help, why is my engine knocking?
Still Knocking
Well, I set the timing to 10 degrees with the sprout connector removed, engine warm. I ran 87 octane through for 2 tanks and it's knocking like crazy on 0F degree days.
Haven't got it yet. :shrug: :bang:
From what I've found, winter gas is more oxygenated which isn't going to help the pinging at all. Todays 87 is just a step above Propane. Don't run that trash. Don't throw in a whole tank of 93, but just try maybe 1/4 a tank and see if it works first before you fill her up.
Joe
95GTvert[bv12] said:
did you try replacing the sensors yet? also try using 89 octane...but you should be able to run 87 octane with 10* base line
I replaced ECT, AIT, and cleaned the Maf.
Joe
I put in 10 gallons of 93 and the knocking went away.
Do I just have to live with more octane.
BTW, Over the years I have found that running 93 I get about 20% better mileage. Which pays for the 93 octane. I'll have to keep my eye on it now that I have made changes.
