Taken from Modularfox.com this is from modular93 fox.
From donor car needed: Additional/optional:
* Motor / Transmission
* Motor harness' & Transmission harness
* Hydroboost Brake system with matching hoses
* 4.6 pedal assembly (or modify booster to pedal rod)
* Mass airflow sensor and intake tube (or purchase cold air intake kit)
* Calipers w/stock flex lines & matching banjo bolt (if you upgrade to 5-lug 99+ has better calipers than >98)
* Stock 4.6 Driveshaft
* Stock 4.6 Motor mounts
* Stock 4.6 H (or aftermarket, either way it will need to be modified to fit fox crossmemebr)
* Stock 4.6 radiator & cooling fan
* Stock 4.6 radiator hoses
* Stock 4.6 radiator hold down brackets
* Stock 4.6 coolant tank and support rod
* Stock 4.6 accelerator cable
* All engine related sensors on the motor, CCRM & Cruise Control Servo
Aftermarket Additional / Optional:
* Russell -6an & -8an Ford EFI rail adapters
* Braided fuel line -6an & -8an
* 190lph fuel pump
* AJE k-member w/ mounts 1" foward (had to slot the AJE-3020)
* Spring perches for k-member (springs need be cut ~ 1 coil)
Re-use:
* Stock 5.0 steering rack and bushings
* Stock 5.0 cross member (relocated)
* Stock 5.0 transmission mount
* Stock 5.0 clutch cable (manual only)
* Stock 5.0 after cat exhaust
Extra costs:
* Re-worked 4.6 h-pipe (to conform better)
* 96-98 Mustang return style fuel rail
* Tune if you go returnstyle and delete rear o2 sensors/purge valve and misc. sensors
Upgrading to 5 lug (if you choose)
* See article on axels, and sn95 spindles @
http://sn95brakes.cjb.net/
Modify:
* Cross member mounts
* Power brake hole 4 th hole
* 3-2 brake line “t” (cut and flare method)
* Passenger side brake line fitting (cut and flare)
* Radiator mounting bracket
* Fabricate coolant tank mounting bracket
