I am in the process of doing a 5-lug conversion on my 85. Whats the difference between the fox length 5 lug axles and the SN95 axles?
Thanks
Thanks
marine_2003 said:So if i get Sn95 axles it will stick out about 3/4 of an inch more?
jrichker said:See http://www.svo73mm.cjb.net/ for help. Matt90GT's site has everything you need to know. about Mustang brakes.
If Matt90GT said your 85 was good, it is good. Just be sure that your model of 85 M/C matches what is in his website. The SVO's had the proper M/C, the other models did not.marine_2003 said:http://www.svo73mm.cjb.net/
Checked out site, a lot of help but i still have a few questions. When upgrading my Brake Booster, which one to use? A 93 Cobra, a 94-98 Cobra? The web page says that since mines an 85, i can use the same M/C. I just need to gut it and put in the adjustable PV.
Thanks
Anthony
Thanks
Anthony
mansonozz said:The extra length on the axles is like a Godsend, I don't see why anyone would question or not even like it. It's perfect!
9 Deuce GT said:It's great DEPENDING on your wheel selection. If you use a 9" wheel with 24mm offset, it will stick out.
Shakerhood said:If you want to run the 9" Wheel out back with the SN95 Axles you need a wheel with 6.42" Backspacing.
5LugFoxFanatic said:I did this conversion on my 86. Just keep the stock booster and swith the master to an 85 lincoln towncar. Buy a adjustable proportioning valve, and gut the stock one, and you'll be styling. I use this setup and I stop fine. The pedal is not too stiff and stops on a dime. I use 99 Calipers in the front though. Thought about stepping up to Cobra's but it stops so much better than stock, I just have not bothered, and I autocross my car alot, and have never boiled the fluid or experienced any brake fade. The Cobra's stop better and look cooler, but I don't think I need it. I need a torque arm....yeah, that's what I need.
9 Deuce GT said:I know this. But I was commenting on the general answer "The extra length on the axles is like a Godsend, I don't see why anyone would question or not even like it. It's perfect!".
It matters on the setup is what I was getting at. For me, and the wheels I want, an axle that was 3/8" longer would be perfect for "my" combo.
It's not always cut and dry.
