- Sep 1, 2005
- 63
- 0
- 0
New to this site. A lot of you guys seem very knowledgable as I read through your posts. I purchased a 68 coup several months ago and thought I'd re-live my teenage years again. I have owned half a dozen stangs 19+ years ago and my 65 fastback was my favorite. Here is what I started out with component wise in my 68 coupe.
Fresh 302
shorty headers
GT40-P cast iron heads
Edelbrock performer
Holly Street Avenger 570
After purchasing the 68 I installed a comp cam and gear drive two weeks later. It is their 280H-10 with 512 lift and 280 duration. I love the sound of a nice cam. Everything was good. I then put accel 8.8mm wires, new cap, rotor, and points. Started to miss slightly then progressed over a period of several days. Switched from my Holley to an Edelbrock a friend had. Ran OK without the miss but a little rich. Found out it was a 750. Didn't like the mini turbo mufflers so I had thrush glasspacks installed and had the tips run out in front of my rear wheels like the 65 GT350. Still running like crap. Tried several other carbs and still runs like crap. Ingition right? So the other day I purchased the Accel pointless conversion kit from Schucks. Also purchased an Accel coil, what the heck. It was a snap to install. Followed the directions to the T. Got her started and timed(about 34 degrees advanced). Started popping throught the carb and exhaust. I saw this coming so I dipped my avenger the night before. Went back to Schucks and got a rebuild kit for the Holley. Rebuilt the Holley and stuck it on. Ok, it's going to scream now.
Now it idles crappy and pops out the exhaust when I accelerate. I used to be a good shade tree mechanic when I was younger. I have done so much to the mustang it's hard to pin point one thing. I think it's the ignition. Has anyone had problems with the Accel? I did pull the cap and found burn spots next to all the copper terminals. I changed the cap and it is not having the hot spot problem now. I don't know exactly when that occured though. I hate to put the points back in to see if that is the problem but I may have to do that just to start a process of elimination. I took #5 wire off and stuck it on another plug I had in my tool box. I looked like it was not getting hardly any spark at all.
I'm at my witts end :damnit: Please help. I hope this all makes a little sense.
Thanks!
Mike.
Fresh 302
shorty headers
Edelbrock performer
Thanks!
Mike.
I have read that some have used the pertronix and had to use a direct 12V current. I will try the temp bypass and see what happens.
