Help with Autometer gauge
When I did my gauges, I just went to an auto parts store that had many brass fittings. I did one for the water and for the oil. I just pieced it together after a few minutes and a little help with all senders. I have to do it again in a week myself since I have new gauges for my new car. That is what I will do.
Chris
IIRC: stock sender is 1/4" NPT fittings. many aftermarket gauges are 1/8" NPT. so, as Chris (and i) did, take the stuff to the parts store and match it up, piece it together. i had to run an extension (1.5" IIRC) off the hex tube on the block to get clearance for two elec senders. then some adapters to adapt the Tee fitting for each sender, etc.
good luck.
