HELP! with brakes
  • Thread starter Thread starter 88LX
  • Start date Start date Oct 27, 2005
88LX
327
Chicago, IL
Oct 27, 2005
  • Oct 27, 2005
a couple of problems: installed new KYBs all around, SS brakes hoses, SS sleeves, HAWK pads and new calipers. when i brake hard it still pulls to the right. and when i turn the wheel while NOT moving it seems to take a little more effort than usual. as if the tires dont want to move and then all of a sudden break free. i bled the brakes, maybe i have to do it more. i checked for rubbing. any suggestions? thanks
R
Randy Kemper
102
  • Oct 27, 2005
I would double check everything, which I'm sure you have. Also I see you replaced everything but the rotors. Have you even had them turned? I would look at that as a possible problem. If everything else needed replacing, I'm sure the rotors needed some attention.
88LX
327
Chicago, IL
Oct 30, 2005
  • Oct 30, 2005
yeah, the rotors. they kinda slipped my mind and i didnt even turn them. ill have to do something with them. thanks. anyone else?
T
THC420
Banned
Dec 18, 2001
202
Ontario, Canada
Oct 30, 2005
  • Oct 30, 2005
I would say the rotors. Buy new ones, if your old ones are warped turning them is only a bandaid solution and you will be doing it sooner rather then later.
Also check the hardlines and make sure none of them are pinched or leaking, as this would cause a loss of fluid to the one side and cause the pulling when braking as you described.
Front brakes not releasing
  • Boats90GT
  • Sep 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
Boats90GT
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
3K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
CHANGING BRAKE PADS
  • Scwhitten
  • Jun 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 12, 2026
nickyb
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
