My cruise control doesn't work at all so I need some help ascertaining the problem. Here is what I checked so far:
1. All fuses in the fuse box are okay.
2. The VSS is working properly. Just for kicks I swaped it with a known good one and same result.
3. I can't find any vaccum leaks.
4. With the car off I connected a vaccum pump to the vaccum for the servo coming from the vaccum block. I pulled 23 inches of vaccum on it and let it sit. The vaccum slowly bled off. In less than a minute it was down to zero. Is this an indication of a bad servo, or will it not hold vaccum if the engine is off? I hope not because I removed the inner fender well and the servo looks like its a b**** to pull off.
Here is what I haven't checked:
1. Brake switch. Where is it? I assume it's on the brake pedal somewhere, but I looked up under the dash and didn't see anything.
2. Cruise control buttons. How do you determine if these are bad.
Any help is much appreciated.
