When the car revs 2200rpm+, I start to notice ALOT of vibration in my shifter. Sometimes it's unbearable and it really gets on my nerves. Any good ways of dampening it or eliminating it? (Shifter is a Steeda Tri-ax on a T5 trans)
maverick0716 said:Changing the shifter back to stock will do absolutely nothing. Mine has done it since I bought the car and when I put on my Steeda Tri-Ax it was still there.
HISSIN50 said:i was actually kidding about him putting the stock shifter back in. people often notice that when they go with an aftermarket shifter (and now dont have the rubber isolator in the handle), there are more vibs. i would not actually do it.
i think your logic is a little flawed. if you had vibs with a stock shifter, no aftermarket shifter would quell the vibes. sorta like installing a turbo to smooth out a part-throttle miss.
i think you just need to lay off the mods.![]()
we are cool.maverick0716 said:I didn't buy the shifter to smooth out a vibration......thats just plain stupid. I was just saying that it wouldn't if thats what you were thinking (being more stiff and having a stiffer spring, some people might think that.)
5.0guy said:u talking about the trans crossmember? if not, that could be it, too...the bushings on the end of mine are shot. I'm gonna get an adjustable Ford Racing one soon.
cjman15 said:I ordered that adjustable crossmember awhile back because I thought I needed it for my T5 conversion, but tha trans guy said I could reuse tha AOD one... The firewall always seemed to vibrate the most when it was AOD and tha engine would roar... now it's in the firewall and shifter...
it will play optical tricks on your eyes (atleast mine). i had to block out the rear part of the balancer, as it made it appear to oscillate.92greenlx said:I have 178,000 miles on my car now. When my car is running and I look down at my harmonic balancer it looks like its warped or is that how its suppose to look when it is turning? So that has to be my problem!
