help with fan
  • Thread starter Thread starter Dtowncats
  • Start date Start date Sep 19, 2004
D
Dtowncats
340
York, PA
Sep 19, 2004
  • Sep 19, 2004
I put a new tranny in my car and while the old tranny was out I never supported the engine so it just hung there. When I got the new tranny in the car and fired it up I could hear the fan hitting the fan shroud at the bottom. What can I do to fix this?
HISSIN50
34
129
Sep 19, 2004
  • Sep 19, 2004
how do your motor mounts look now? is the fan hitting the top or bottom of the shroud?
i might guess your old mounts were about toast and then your endeavors toasted them all the way.
good luck.
D
Dtowncats
340
York, PA
Sep 20, 2004
  • Sep 20, 2004
I haven't looked at my motor mounts yet but when I drove it, it didn't feel like they were bad. The fan is hitting the bottom of the shroud.
BlownStangGT
REPEAT
3,860
Lancaster, PA
Sep 20, 2004
  • Sep 20, 2004
im assuming from having the motor sitting there with the trans out it shouldnt really have moved, but maybe your mounts r that shot....id check into that
TrophyHead
1,195
11
49
PA
Sep 20, 2004
  • Sep 20, 2004
When I had my tranny off. The fan didnt hit the shroud. I just put new motor mounts on before I did the tranny. I also say check those motor mounts.
That's why an electric fan is awesome. Wish I had a 130A alternator though.
D
Dtowncats
340
York, PA
Sep 21, 2004
  • Sep 21, 2004
So how do I know that my motor mounts are bad? If they are, what kind should I get to replace them?
HISSIN50
34
129
Sep 21, 2004
  • Sep 21, 2004
one sign they are bad is the fan hitting the bottom of the shroud.
take a look at them - sometimes you can see that they are sagged out or broken.
as for choices: if using parts store mounts (~40 bucks for both sides), get ones for a 93. they are the captured convertible mount design. or for 3 times the price you can get some poly's. if i had the money i might have done those......
D
Dtowncats
340
York, PA
Sep 25, 2004
  • Sep 25, 2004
Ok well I am going to replace my motor mounts... Now which ones should I go with. There are the convertible mounts, polyurethane mounts, and solid mounts. There are two companies thta make poly mounts, Prothane and Energy. Energy ones are more expensive but is Prothane good? And what are the good and bad about solid ones? Do they give off more vibration? Any replies would help. Thanks.
HISSIN50
34
129
Sep 25, 2004
  • Sep 25, 2004
a search in here will reveal a lot of info (if the function is working).
solid mounts can transmit a good deal of vibes - everyone has a different threshold of what is acceptable. probably dont want to use solid mounts on everything (motor and trans). i would take a look at your trans mount now too - do them all at once. the trans mount is dirt cheap.
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
Engine Radiator with no shroud provision... What to do?
  • FastDriver
  • Apr 22, 2026
Fox 5.0 Mustang Tech Apr 25, 2026
FastDriver
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
Engine Which cooling part first?
  • Dontknowchit
  • May 8, 2025
Fox 5.0 Mustang Tech May 15, 2025
90trunk
