help with harmonic balancers
  • Thread starter Thread starter allcarfan
  • Start date Start date Jun 11, 2004
allcarfan
The Answer Man
2,458
North Atlanta
Jun 11, 2004
  • Jun 11, 2004
I have a brand new crank that needs to be balanced. I have a late model 302 block with vbelt pulleys. I guess I can get a 28oz or 50oz balancer and matching flexplate? Do i have to buy any spacers or anything like that?
Shane
67coupe351w
424
Portland, OR
Jun 11, 2004
  • Jun 11, 2004
Is the crank intended for a late model 302? If so you would need the 50 oz balancer and flexplate.
If its intended for an early 302 your going need the 28 oz options. If you dont know which you'll probably have to ask the manufacturer, I dont know if a machine shop can tell what it is or not.
As far as I know the cranks should be the same with no spacers required. Any one know?
66P51GT
721
Cerritos, CA
Jun 11, 2004
  • Jun 11, 2004
Most aftermarket harmonic balancers require a spacer to run a serpentine system. They should work fine for your v-belts. Cranks have the same output shaft diameters so both types of balancers will fit. You just need to determine which one to use.
You can't put a 28oz. flywheel and balancer on a crank that was meant for a 50oz. I have a late model 5.0 which needs a 50oz. balancer. You can purchase harmonic balancers for this crank for use with your 3-Bolt pulleys and v-belts. This is the approach I am taking to avoid clearance problems with serpentine systems and the front radiator.
There are some good deals to be had on Ebay for what you need. Click here.
allcarfan
The Answer Man
2,458
North Atlanta
Jun 11, 2004
  • Jun 11, 2004
the machine shop said they would check it out and tell me what I need
L
1996 harmonic balancer crank bolt. Help!
  • Lost in Palm Bay
  • Jul 21, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 24, 2026
Lost in Palm Bay
L
J
Resolved Ford 302 damper issue
  • James S
  • Aug 8, 2026
  • Other Auto Tech
Other Auto Tech Aug 8, 2026
James S
J
Motor ID
  • 65er
  • Mar 14, 2026
1965 - 1973 Classic Mustangs -General/Talk- Mar 14, 2026
Help. 1968 engine swap to 95 5.0
  • superdog68
  • Jun 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 23, 2025
Mcmahst
D
Harmonic Balancer brand, weight?
  • dropteeth
  • Sep 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2025
revhead347
