  • SN95 4.6L Mustang Tech
Help with Headswap in NC
  • Thread starter Thread starter OH-58D Driver
  • Start date Start date Apr 17, 2004
OH-58D Driver
83
Raeford, NC
Apr 17, 2004
  • Apr 17, 2004
I just bought a set of 99 heads from a guy in the classifieds here. When I received the heads yesterday, they were in the same box... A little bit of surface damage, but not bad enough to prevent an install. Then I notice the R/H head has a tag on the cam sprocket that reads "Cam not Torqued" so I start wondering why. I looked at the number 6 cam cap, and it's cracked.
I have also purchased a set of SHM 2730's to put in the heads before I do the swap.
How can I fix the cracked cam cap. Everything else looks to be in good working order. Does anybody know a shop in NC that can install the cams and replace the cam cap?
Thanks in advance,
Tim
J
Jr2fast
1,097
Mannford, OK
Apr 17, 2004
  • Apr 17, 2004
you need a new cap, talk to ford, or I have a set of caps and PI cams from my 99 heads left over that I can get ya cheap. I would imagine they are a pretty penny from ford not sure though. Just let me know what u need, I have the complete heads just sitting here and I am not going to use them except for paper weights
billyfe390
573
  • Apr 17, 2004
If you replace that cap you will have to have the head line honed.
OH-58D Driver
83
Raeford, NC
Apr 17, 2004
  • Apr 17, 2004
Jr2fast--Thanks alot. I may be hitting you up that, depnding on what a local shop says about putting these cams in for me.
billyfe390--I'm not too familiar with head work, but I thought it only needed to be honed if the end play was too tight.
Tim
billyfe390
573
  • Apr 17, 2004
Tim
The cam caps are individual to each other like main caps in the engine. When they are made the caps are torqued onto the head and then they are bored/honed out to the final specification. So if you put a different cap on it will be a different size and could cause problems. When you line hone an engine you get a main bearing/cam journal cap and make it a smaller diameter by milling it down then you hone out the bore to the specs you need.
OH-58D Driver
83
Raeford, NC
Apr 17, 2004
  • Apr 17, 2004
billyfe390--Thanks for that info. I'm learning as I go. I used to do front end work for a Ford dealership before I joined the Army, but I never got into engine work.
Tim
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Engine Head/Cam Recommendations
  • CWSpartan
  • May 29, 2024
SN95 4.6L Mustang Tech May 31, 2024
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
Misfire or knock after ignition tune up
  • sleeprtsi
  • Jul 22, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 27, 2024
General karthief
