heads
Ill tell you everything ive got. A performer rpm intake, performer rpm heads w/60cc chambers and 1.9 inch intake valves. A set of tri-y headers, and flowmaster 40's dual exhaust. Im currently running the performer plus cam, but it doesnt match that well with the rpm series. So i wanted to get the matching cam for the heads and intake. But i needed at least a 9.5:1 comp ratio. My engine has been bored over .030, and i never took the time to check the comp ratio when it was all together. Now that its apart i cant tell what the ratio is. Im not very knowledgable about ratio's so im not sure if i already had a high enough ratio with these previously mentioned parts and bore. So basically i want to kno whether i can go ahead and put in the cam or i whether i need to increase the ratio in order to properly run the engine, without burning it up.
