Help With Lean Pop
  • Thread starter Thread starter gtcobra302
  • Start date Start date Nov 15, 2005
gtcobra302
118
Centra Florida
Nov 15, 2005
  • Nov 15, 2005
I have a 1989 mustang Gt. It has developed a lean pop at low rpms when under load. It kind of sounds like it is back firing through the intake manifold. Just when cruising at lower rpm's, if you get on it it goes on by it at about 2500 rpm's. any ideas would be greatly appreciated. This is what is on it in that department. Trick flow intake manifold, 70 mm t-body, 73 mm mass air, 24 lb injectors, fuel pressure at 40 psi, ported and polished gt40 heads, tps at .98, 255 lph fuel pump.
thanks
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 15, 2005
  • Nov 15, 2005
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
18mustangs
533
Virginia Beach, VA
Nov 15, 2005
  • Nov 15, 2005
thanks
Have you deleted EGR, and if you did delete EGR did you turn it off in the computer? How new are your sensors, specifically the ECT and ACT sensors? Also clean the MAF for good measure and maybe the ACT as well. If you haven't given the car a good tune up in a while you might want to replace the fuel filter, check your cap, rotar for corrosion and your plugs..just the basic stuff in case it is pinging instead of a back fire. Also 02 sensors can cause the ping or backfire if they're not working properly. Check the codes and see what comes up. With the setup that you have I'd recommend lowering the fuel pressure as well at least back to stock (if 40 PSI is vacuum on and you have an AFPR) or perhaps a little lower.
Tim
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Engine Popping noise in the intake. Frustrated still.
  • esteban31065
  • Apr 6, 2025
Fox 5.0 Mustang Tech May 23, 2025
gkomo
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
