Help with lower intake gaskets *pics*
  • Thread starter Thread starter ShortThrow50
  • Start date Start date Jun 27, 2007
ShortThrow50
923
Pa
Jun 27, 2007
  • Jun 27, 2007
I did tfs h/c/i. I sprung a little coolant leak so im replacing the gaskets and gonna do it right this time. Im gonna put some black rtv around the coolant passages this time. I bought a new felpro gasket kit and confused about some things. I labeled the picture with numbers.
whats 1 and 2 for?
Do i cut number 3 to fit the water passages?
thanks
Rick 91GT
Mustang Master
95
99
PA
Jun 27, 2007
  • Jun 27, 2007
#1 is if you have an active EGR system you put those on the spots in the middle of the gasket, like a puzzle piece.
#2 if you have eliminated or plan to block the EGR you install those instead.
Either way make sure you cut out the small leg that is in each water port #3 and but rtv around them, I also prefer to use a bead across the front and rear of the intake as well instead of the cork pieces.
The ??? is a new oring for the dist, yours is most likely dry rotted...
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Jun 27, 2007
  • Jun 27, 2007
Yup and if you do use the cork for the lifter valley (front and rear) don't forget some RTV on the 4 corners where the intake meets the head and engine block (lifter valley).
Silver Fox 90
  • Jun 27, 2007
When I redid mine in the lifter valley i put a bed of black rtv, then set the cork in that and then a small bead on top to be damn sure the ends didnt leak
Sicarius428
2,085
Jun 27, 2007
  • Jun 27, 2007
oh brother... i just realized i forgot to put the egr tabs in. Crap...
Kevin
Boss 351
Jul 13, 2003
2,433
23
48
Canada
Jun 27, 2007
  • Jun 27, 2007
I plugged the EGR hehe no need to heat up the intake for a weekend car
Sicarius428
2,085
Jun 27, 2007
  • Jun 27, 2007
I live in CA so I didn't block them. I wonder how burnt my intake gaskets are....
Kevin
ShortThrow50
923
Pa
Jun 27, 2007
  • Jun 27, 2007
good thing i asked because the first set i did not use the egr gaskets. i didnt know what the heck they were for. I do have an active egr. Thanks guys
Engine 5.0 Head Gaskets installed wrong block coolant passages???
  • Xam Sirrah
  • Jul 21, 2025
Fox 5.0 Mustang Tech Dec 22, 2025
Qtrhrse23
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
Engine Head gasket port matching plus head/intake port alignment
  • PonyGTrider
  • Dec 10, 2024
Fox 5.0 Mustang Tech Dec 12, 2024
PonyGTrider
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
