I have a 69 stang with a supposed 302 that will only run with the cam 180 out. It doesn't run right but will start after a pop back through the carb. It runs like its not hitting on all cylinders. I know the firing order and all components are new. Could it have a cam from some other engine? I have never seen anything like it. Can you help get to the bottom of this mystery?
Your distributor is 180* off. Put your #1 piston at TDC on the firing stroke, then look to see where the rotor is pointing.
