help with my combo ???!!!!!
  • Thread starter Thread starter Markus
  • Start date Start date Feb 4, 2006
Markus
238
germany
Feb 4, 2006
  • Feb 4, 2006
Hello,
i need help with my engine combo. I don´t know
whether the combination of my parts is feasiblly.
-5.0 block (roller) zerodecked
- 5.4 forged probe -4cc
- 3.25 stroke
- 4.03 bore
- 0.039 head gasket (compressed thickness)
- AFR185 61cc (out of the box, this means .550 max lift)
- desired cam compcam XE270HR, 218/224, .512/.512
ABDC @0.006 65/@0.05 39
- EFI
- car weights 3100lbs
- 3.55 rear and five speed tremec TKO
- 99% street use, that means good idle and low end torque
- max rpm 5800-6000
My computed static compression ratio is around 10.2 : 1.
My computed dynamic compression ratio is around 8.8 : 1.
Would be my cylinder pressure too high?
The use of premium gas is not the problem.
I´m confused with the cam and/or my math. I my calcul of
the DCR correct?
Is ABDC computed with 0.006 or 0.05 lift?
thank all for help.
Markus
sorry for my rough english!!!!!!
old_blue
1,783
282
124
Feb 4, 2006
  • Feb 4, 2006
I will have to agree with others that will eventually chime here to get a custom grind cam. With all that money into it you might as well utilize it all with the appropriate cam
304billet
315
  • Feb 4, 2006
I would have the springs upgraded to .600 lift and go with the XE282HR. u should not limit the potential power due to valve springs max lift. I have seen 331 strokers run really strong with AFR 205's.
Go with a Victor EFI or TFS-R intake port matched.
Don't know about all ur calculations there, but my old 347 stroker w/ ported AFR 185's, ported Downs intake, Comp Cam XE282HR w/ 10.3:1 comp put down 400/400 @ the RW, NA on pump gas. It had SRP flat tops.
Engine An engine building combo with stock Speed Density (SD) system
  • Mcmahst
  • Jan 14, 2025
Fox 5.0 Mustang Tech Jan 15, 2025
Mcmahst
V
pushrod 5.0 (MILD/ Torque) turbo build for an old scout II help
  • vz58
  • Apr 21, 2024
  • Other Auto Tech
2K
Other Auto Tech Jan 21, 2026
Flyboy60
F
Engine Help Me With Throttle Body And Injector Sizing
  • stealth886
  • Nov 28, 2016
10K
Fox 5.0 Mustang Tech Dec 6, 2016
RangerJoe
427w Engine Build
  • LuckyM95
  • Nov 12, 2016
17K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 11, 2016
LuckyM95
Can someone help me decide what pistons to use???
  • bdazzgt
  • Aug 29, 2010
Fox 5.0 Mustang Tech Sep 4, 2010
bdazzgt
