Help with oil problems.
unmarkedcoupe
9
OK ill start from the begining I have a 89 coupe EFI with bolt ons stock 302 internals.Well the latest bolt ons where A Holly sytemax intake While doing the intake added a TFS Stage 1 cam.THe problem is i keep blowing oil out the pcv valve.Well it was first ran to intake wich made alot of smoke.So i went and got another brand new Pcv and still was doing it.So we ran a rubber hose from Pvc to open air to see what it would do.Well it Jus shoots out the oil.THios only happens when i give it almost or full acceleration.
What causes this?
If it were crank case pressure wouldent it have done it on stock intake also and blow out smoke?I had not even the smallest amout of smoke ever before.So that to me rules out crank case due to the fact it wasent bad before.
Any ideas at all?
I have the same problem. Ever since I put the TFS on. have and in-line separator between the PCV valve and the intake and still get oil. The problem it seems to cause is oil soaks the gasket between the upper and lower intake at the back 2 runners after a couple hundred miles. This leads to a, what I assume is a vacuum leak between those runners, miss at higher rpms. If I replace the gasket, it goes away until the gasket soaks again. I also did not have this with the stock intake. All parts (PCV) have been changed. All baffles in place.
Not trying to hijack, but have the same problem, researched through the forums and tried the various fixes which have not worked yet. :(
