Help with PCV hookup
bigcahoona
74
Chi Town
A friend of mine installed a new upper and lower intake on a 86 5.0 and he said he had smoke coming from the back of the lower intake. Well when I looked at it I seen he did not install the PCV. When he installs the new PCV where do the hoses go. We looked at mine but it's been changed around because it's supercharged and I forgot the stock setup.
3/8 hose should go from the pcv valve to a vacuum port on the underside of the upper. On my gt40 intake you can see if if you look under the upper intake from the drivers side. Its near the rear close to the vacuum tree.
