Help with rack bushings
  • Thread starter Thread starter 93gtsbc
  • Start date Start date Dec 29, 2010
9
93gtsbc
Central Mo
Dec 29, 2010
  • Dec 29, 2010
Hello to everyone. This is my first post. I have a 93GT that I have everything completely removed from the front of the car. This is not my first fox project but it is the first one to go this far. I purchased a used tubular kmember. I think it is qa1 because it has the bolt on plates to run the stock springs if you want. I bought a new manual rack from unisteer. It is a quick ratio. It came with the sleeve and two bushings per side. The bushings fit the rack and the sleeves are good in the bushings. The sleeves will not go on the mounting stubs of the k member. These are the stubs/stand offs that are threaded to replace the factory long bolts. It is not even close. The sleeve is only about 1/8 biger od than the stub it goes on. If you drill the center it would be too thin. I know I am not the first one with this problem.
#2 I am getting rid of the brake booster and going manual. I have the block. Can I use the original power MC with the block or does it have to be a non power MC. I have several other questions but these are at the top of the list. Thanks
9
93gtsbc
Central Mo
Dec 30, 2010
  • Dec 30, 2010
30+ views and no response. I know Im not the first person to have this problem. I called unisteer and they are on vacation until the first of the year.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 30, 2010
  • Dec 30, 2010
Not everyone has the same aftermarket parts as you do. I certainly don't, and I have no experience with the QA1 product.
Those 30 views were probably from guys who had the stock K member and steering rack. I am sure that if you had the stock parts that one of them would have had the answer to your problem.
9
93gtsbc
Central Mo
Dec 30, 2010
  • Dec 30, 2010
I understand and Im not trying to be rude. You would think that whoever designs the kmembers would use a stub that has the same od as the factory sleeve. This is the hard part about piecing something together with an assortment of parts but If I had too buy it all in a new kit it would be out of my price range
9
93gtsbc
Central Mo
Dec 30, 2010
  • Dec 30, 2010
I took a caliper to the shop tonight. The stub that the rack mounts on is .750od the sleeve that they send is .610id. Still researching.
9
93gtsbc
Central Mo
Jan 3, 2011
  • Jan 3, 2011
It would be helpful if someone could tell be the size of the stub on their kmember. I am wondering if mine is odd. I have yet to see any rack bushings that are .750 id
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Tightening upper control arm bushings at ride height dilemma… need some help
  • AnthonyA1234
  • Dec 27, 2024
  • 2 3
6K
Fox 5.0 Mustang Tech Feb 27, 2025
General karthief
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
