Help with ring install
  • Thread starter Thread starter stockhatch
  • Start date Start date May 27, 2006
stockhatch
536
polar sloth country
May 27, 2006
  • May 27, 2006
I have rebuilt a couple motors before and never had this problem... This rebuild, I am using Sealed power moly rings on a stock piston/bore. The issue is the oil control rings. The wavy center section of the oil control ring is holding the two thin oil rings out, not allowing them to compress(at least not easily) Is this where I crank the suckers down in the ring compressor?(ie brute force approach) Im pretty sure the rings are correct. They are E458Ks. I have already filed all the gaps on the top two rings, so Im ready to move ahead with this.
TIA
stockhatch
536
polar sloth country
May 27, 2006
  • May 27, 2006
Nevermind. It just took a little mashing in the ring compressor. Not bad at all, and they popped right in the bores. I guess trying to test mash them my hand was decievingly difficult.
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
Progress Thread "Alter Ego" White 1993 LX 5.0 5spd
  • idareu
  • Sep 9, 2024
  • 2 3
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 19, 2025
idareu
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Cpp mini sub install
  • 67coupestang
  • Sep 13, 2021
4K
1965 - 1973 Classic Mustangs -General/Talk- Sep 18, 2021
wicked93gs
Engine Head gasket or what?
  • Foxbody1988
  • Jan 17, 2020
4K
Fox 5.0 Mustang Tech Jan 19, 2020
7991LXnSHO
