Help with ring install
stockhatch
536
polar sloth country
I have rebuilt a couple motors before and never had this problem... This rebuild, I am using Sealed power moly rings on a stock piston/bore. The issue is the oil control rings. The wavy center section of the oil control ring is holding the two thin oil rings out, not allowing them to compress(at least not easily) Is this where I crank the suckers down in the ring compressor?(ie brute force approach) Im pretty sure the rings are correct. They are E458Ks. I have already filed all the gaps on the top two rings, so Im ready to move ahead with this.
TIA
