  • 1994 - 1995 Specific Tech
Help with T5
  • Thread starter Thread starter 95kobrah
  • Start date Start date Oct 28, 2004
95kobrah
387
Ohio
Oct 28, 2004
  • Oct 28, 2004
Well, the T5 in my cobra has no second gear what-so-ever and first is starting to pop itself out sometimes, much like second did before it went completely. 3,4,5,R work perfectly though. Would you guys suggest:
A:rebuild the T5 (no experience with trannys but i think i can do it)
B:New T5 SuperDuty with 2.95 1st ect.. from somewhere like Summit
C:G-force
D:Tremec
now i know that the tremec is what everyone will probably say is the best, but you know the story, "limited budget". What all do i need if i saved for the tremec? new bellhousing i know, how about the clutch, i just put a kingcobra clutch in not too long ago along with a tri-ax and clutch quadrant ect.also have the speedcal and 3.73's, stock drive-shaft. What all can i keep from those parts if i got a tremec? Thanks for the help guys, i want to be able to drive the car next spring, and i dont see much excitiment trying to get moving from 3rd gear lol.
95kobrah
387
Ohio
Oct 29, 2004
  • Oct 29, 2004
anyone?
slytherin
702
northeast ohio
Oct 29, 2004
  • Oct 29, 2004
Stay far away from G-force their customer service blows. The T5's for sale in the mags are the ones for fox body cars from what I was told about this time last year when my T5 let loose when I bought my 3550 tremec - well now it's the 500 and 600 tranny's. IMO the T5 isn't worth a rebuild either for the money you would spend on doing that you would be better off spending the xtra cash on a better tranny that will handle more power especially if you do more mods down the road.
OrangeMustangGt
1,976
Cape Cod, MA
Oct 29, 2004
  • Oct 29, 2004
im in the same boat as you tranny wise. this is what im doing, i just ordered a 20$ video from mustangs unlimited on a step-by-step rebuild that seems pretty easy. then in mm+ff mag in the back is a rebuild kit for 159. shipped for the rebuild kit. for the price, and how easy it appears after watching the video, ide say you would be stupid not to rebuild it unless your making ungodly power.
95kobrah
387
Ohio
Nov 4, 2004
  • Nov 4, 2004
Ok, my big question, if i get a Tremec for my 95 cobra, a TKO 3550... what additional parts do i need?
-bellhousing?
-Clutch/flywheel?
-Drive shaft?
-Quadrant?
right now in my car i have the stock bellhousing, driveshaft, and quadrant, and the clutch is a king cobra, and the flywheel was recently resurfaced when i replaced the clutch. Please respond because i need to know before i purchase a tranny and then find out it wont fit. Thanks for the help in advance
Joes95GT
3,132
Delaware
Nov 4, 2004
  • Nov 4, 2004
If it's popping out of gear, that means the blocker rings are bad. Those are an easy fix.
I'd go with a T5 rebuild...
Joe
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
