  • SN95 4.6L Mustang Tech
help with u/d pullies
  • Thread starter Thread starter zinc281
  • Start date Start date Oct 17, 2004
Z
zinc281
Virginia
Oct 17, 2004
  • Oct 17, 2004
Im trying to put on my steeda pullies and cant get the alt.nut or the crank bolt out to take off my stock pullies,im using a 350ft/lb impact and nothing! Should i go with a 500/700 ft/lb or maybe a 3/4".This is on an 02'gt any help would be great.
Squad
21
Cornelius, NC
Oct 17, 2004
  • Oct 17, 2004
You need to get a puller for the crank pulley, it bolts on to the 3? bolts holding the pulley on. We tried with an impact wrenck and it was a no go, had to get the puller.
E
El Diablo
53
  • Oct 18, 2004
For the crank bolt, put a 1/2 inch breaker bar with socket and beat it with a hammer. That's how I got mine off. Sounds dumb but, it breaks it free. The alternator bolt should come off with the impact gun. Make sure the belt is on when you are trying to get the bolts off.
E
eleanor'03
117
  • Oct 18, 2004
j/ put mine in sunday...the alt nut should come out w/ impact gun..make sure u got the right socket in there...as far as the crank pulley goes...take a crobar and wedge it b/w the crank and the pulley beside it...then take the bolt off and then use a harmonic balancer puller to get it off...u might wanna wd-40 the crank pulley nut..i did
J
jbrown
393
Tallahassee, FL
Oct 18, 2004
  • Oct 18, 2004
you need a good impact to get off the alternator bolt, I tried using my parents impact and after nearly stripping the bolt they told me they got it for free with the air compressor(i dont know what it was rated at). You can get a loaner puller from autozone.
Help. 1968 engine swap to 95 5.0
  • superdog68
  • Jun 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jun 23, 2025
Mcmahst
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
1999 Mustang GT - No Start- Need help understanding the fuel pump circuit and how it works
  • 99gtGuy
  • Nov 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 7, 2025
04newedge-
D
Foxbody Misfire 5.0 Swap
  • DPORTER0729
  • May 2, 2025
Fox 5.0 Mustang Tech Jul 13, 2025
90sickfox
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
