  • SN95 4.6L Mustang Tech
Help With Violent Vibration
  • Thread starter Thread starter dark_viper42
  • Start date Start date Oct 25, 2010
1 of 2 Next Last
D
dark_viper42
  • Oct 25, 2010
My wife's 2001 Mustang GT(140k) 5 speed, has started getting a bad vibration in any gear. It first started showing up anytime the car was holding a constant speed around 1600rpm. Was less noticeable under acceleration or deceleration. Could also hear a slight ticking noise.
Very quickly the vibration has turned violent. Seemed like it was a u joint going out at first, but after changing both of them its still there. Where should I go next?
Vibration happens in all gears including reverse.
I'm thinking broken motor/transmission mounts or the clutch? Looking for some help and direction.
Car is basically stock. Some exhaust work.
Thanks in advance,
Bret
Sonic04GT
844
West Palm Beach, FL
Oct 25, 2010
  • Oct 25, 2010
Looks like you've already named my guesses, U-joints and motor mounts
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 25, 2010
  • Oct 25, 2010
+1 on U-joints
trinity_gt
3,125
81
99
Canada
Oct 25, 2010
  • Oct 25, 2010
The vibration happens in all gears including reverse: Does it happen with the car motionless (i.e. trans in neutral) and revving the engine? If not, you can basically rule out the clutch & flywheel.
Motor mounts wouldn't really cause a "violent vibration". You might get some knocking and banging though.
You say holding speed at 1600RPM: Is the vibration occurring when the engine is at ~1600 in any gear? This is important because 1600 in first gear results in the driveshaft spinning much slower than 1600 in 5th gear. If the vibration is engine speed dependent (e.g. it happens at 1600 no matter the gear) then you're back to the clutch or flywheel I think.
If it's speed related then you might have a damaged driveshaft or have thrown a weight from it.
Has the clutch ever been replaced?
bmylez
21
San Antonio, TX
Oct 25, 2010
  • Oct 25, 2010
wmburns said:
+1 on U-joints
Unless he put in busted, old U-joints, not sure how that could be it.
wmburns
Aug 14, 2009
5,892
514
204
Houston Texas
Oct 25, 2010
  • Oct 25, 2010
Your right. Didn't read the part about having already replaced the U-joint. Gulity of not reading before typing.
Of course a vibration could be from an out of balance drive shaft. Did you index the drive shaft before removing it?
trinity_gt brings up some great points that can help narrow this down.
If the ticking noise changes with the engine RPM, think clutch forward.
If the ticking noise changes with the car's speed, it could still be rear-end related. Consider pulling the rear diff cover and inspecting the gear oil. Examine the diff sump looking for small bits of metal. Also check the condition of the ring/pinion teeth. Look for chips or other rough areas. If the carrier is removed, possible to inspect the wheel bearings and diff carrier bearings for wear. The bearing races must be smooth. The ends of the roller bearings must have rounded edges. If the ends are sharp, the bearing is worn out.
FWIIW, I had a rear end tick on my 2003 GT that turned out to be worn pinion bearings. The frequency of the tick varied with the car's speed. The intensity changed slightly going from power to coast or coast to power. IMO, it simply doesn't make sense to service just the pinion bearings. Install a rebuild kit.
Don't over look the role that motor mounts can play in a problem such as this. In addition to allowing more vibration to be transmitted inside the car, this also allows the motor to set lower in the K-member. This in turn changes the angle of the drive line thus affecting the U-joints.
Consider that the mounts are over 10 years old and may have lived a very hard life.
D
dark_viper42
  • Oct 26, 2010
With the car in neutral I don't get these vibrations at all. I have the rear end on stands right now and the vibration is coming in as soon as the drive shaft starts to spin. I tested R, 1st, and 2nd last night.
I first noticed the vibration is worst at 1600 rpm in any gear. It is not speed related.
Still has the original clutch.
D
dark_viper42
  • Oct 26, 2010
If the ticking noise changes with the car's speed, it could still be rear-end related. Consider pulling the rear diff cover and inspect the gear oil. Look for bits of metal. Also check the condition of the ring/pinion teeth. Look for chip or other rough areas. I the carrier is removed, possible to inspect the wheel bearings and diff carrier bearings for wear.
I did index the drive shaft before removing and the vibration started before I had ever removed the drive shaft so I don't think my issue is there. Didn't see any places on the shaft that looked as if I had lost a balancing weight...
The ticking seemed to get louder with a change in rpm but the speed didn't seem to change. Best way I can think of to describe the sounds is a zip tie that keeps hitting something on every revolution. However as I said the speed of it hitting doesn't seem to change with different road speed or RPM.
Transmission mount looked fine while i was looking last night. Need to work on checking the motor mounts next. Any suggestions on best way to do this?
Also if it was a motor mount with the vibration happen in neutral?
N8Dogg98
3,872
238
184
MN
Oct 26, 2010
  • Oct 26, 2010
I have the same problem, same ticking noise, and same vibration at 1600 RPM. I recently had the clutch replaced, and am curious to find out what is causing this.
trinity_gt
3,125
81
99
Canada
Oct 26, 2010
#10
  • Oct 26, 2010
  • #10
Very puzzling how 1600 engine RPM is the magic number but you don't see the vibration in neutral...
Check the tailhousing bushing where the driveshaft enters the trans. Perhaps the bushing is blown out and the yoke is flopping around.
Check for looseness in the drive flange at the rear axle. Not the U-joints but the actual flange and pinion shaft of the rear axle.
95Vert383AOD
1,133
34
69
New Bedford, MA
Oct 26, 2010
#11
  • Oct 26, 2010
  • #11
Maybe the computer is doing something funny at that rpm under load. Like pulling massive fuel/timing?
D
dark_viper42
#12
  • Oct 26, 2010
  • #12
I wouldn't say that 1600 is the magic RPM. That's just where I first started noticing it.
With the rear end on stands the vibration starts as soon as the drive shaft starts to engage.
D
dark_viper42
#13
  • Oct 26, 2010
  • #13
Pretty sure its not computer related. Its somewhere in the power train.
D
dark_viper42
#14
  • Oct 26, 2010
  • #14
I don't get vibration at all in neutral. 1600 RPM is just where I noticed it most while driving down the road.
I checked the yoke after changing the u joints and there was no play. Did the same at the rear drive flange when i reattached the drive shaft.
I'm going to double check the motor mounts tonight. I don't think that is the problem but I might as well check. If those check out I'm thinking clutch or transmission....
N8Dogg98
3,872
238
184
MN
Oct 26, 2010
#15
  • Oct 26, 2010
  • #15
I notice my vibration worst in 3rd gear at 1600 RPM's... I don't know if it would be transmission related as it seems to happen in other gears, but 3rd gear at 1600 seems to be the worst.
D
dark_viper42
#16
  • Oct 26, 2010
  • #16
And you get no vibration when you not in gear?
If you rolling along at 1600 RPM in 3rd gear and push the clutch in, does the vibration go away or change at all?
Are you driving your car while its like this?
N8Dogg98
3,872
238
184
MN
Oct 26, 2010
#17
  • Oct 26, 2010
  • #17
No vibration when not in gear and the u-joints are fine as I recently installed an aluminum D/S. The vibration goes away if I push the clutch in, and actually it's most noticeable in 3rd gear at 1600 RPM's if I apply light throttle to maintain speed or ever so slightly accelerate.
Yes I am driving my car when I notice it.
D
dark_viper42
#18
  • Oct 26, 2010
  • #18
Any vibrations when taking off?
N8Dogg98
3,872
238
184
MN
Oct 26, 2010
#19
  • Oct 26, 2010
  • #19
Hard to tell, but it is definitely most noticeable when holding a constant speed or accelerating lightly.. again the worst of it occurs around 1600 RPM's
fast97gt
1,082
north carolina
Oct 26, 2010
#20
  • Oct 26, 2010
  • #20
ill shoot, what about the alignment of your trans in the tunnel, mine had an agressive vibe on take off and early in the rpms then mellowed out later. the cause was what seemed to be a good trans mount but had twisted under a load sometime while driving it, thus the trans looking from the rear forward it sat to the passenger side almost touching the sheet metal. i installed a new mount but with dismay, it was the same. i took the x-member off and notched the hole perpendicular to the the originals. doing this worked like it was made for it. i had no more vibes since.
1 of 2 Next Last
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
J
Lack of power on acceleration
  • jameshernandez
  • Aug 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 6, 2026
jameshernandez
J
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
