  • SN95 4.6L Mustang Tech
Help!!!!!!
  • Thread starter Thread starter 313Stang
  • Start date Start date Feb 1, 2004
313Stang
89
Detroit
Feb 1, 2004
  • Feb 1, 2004
Today when I got in my car (96 GT AOD) I started it and when I put it in Drive the voltage gauge dropped for a second, the rpms went really low (below 500) and the engine shut down. Now it doesn't shut down all the time but it does almost shut down until I give it some gas. If I give it a lil gas before I put it in drive it won't do it. Can someone give me some insight before I go nuts. This just started this morning.
R
Red2000GT
2,450
Regina,Sask.Canada
Feb 1, 2004
  • Feb 1, 2004
Actually sounds like a bad battery to me. My winter beater did the same thing until I changed the battery.
313Stang
89
Detroit
Feb 1, 2004
  • Feb 1, 2004
You know my battery does look kinda bad. Thanx
Warprunner
Monroe, Ohio
Feb 1, 2004
  • Feb 1, 2004
Agree
I agree...sounds definitely like the battery.
Warprunner
Monroe, Ohio
Feb 1, 2004
  • Feb 1, 2004
Agree
Ach...Sorry hit the button twice!
yellow2kgt
175
Fishersville,va
Feb 1, 2004
  • Feb 1, 2004
You might want to try cleaning or replacing your IAC valve. I guess it could be a bad battery but if your rpms drop your voltage gauge is also going to drop because your altenator is not spinning as fast. Thus not creating as much voltage. Just take your car to Autozone and have them check your battery for free. If it checks out good then it will probably be the IAC valve.
313Stang
89
Detroit
Feb 1, 2004
  • Feb 1, 2004
Thanx.. This is why i joined this site.. Now where is the IAC valve at and is it something that can be easily replaced?
yellow2kgt
175
Fishersville,va
Feb 1, 2004
  • Feb 1, 2004
Yes the IAC valve is very easy to replace. It is a round silver solenoid that is attached by two bolts. It is bolted to the front of the upper intake(elbow) and has a black hose that hooks on the front of it.(if you do a search for IAC I am sure you will find a picture of it somewhere.) You might want to try taking that off and cleaning the inside out with some carb cleaner. But as others have said, you might want to get your battery checked first. Because if your battery is pulling a lot of charge from the altenator it could slow your idle down a little.
If your car still has the original battery in it then You might want to go ahead and replace it regardless, Because with it being 7-8 years old it is only a matter of time before it craps out on you.
313Stang
89
Detroit
Feb 1, 2004
  • Feb 1, 2004
Thanx fellas.. I took the battery to be tested and it turned out to be bad... bought a red top optima and the problem has went away...
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
Engine Fuel not pumping
  • Creomod
  • Apr 13, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 22, 2026
Mach 1 iac valve in a 4.6 gt
  • solodriverz
  • Jun 3, 2026
SN95 4.6L Mustang Tech Jun 5, 2026
squeak93
