  • 2.3L (N/A & Turbo) Tech
HELP!
  • Thread starter Thread starter QangMartoq
  • Start date Start date Jun 26, 2004
Q
QangMartoq
37
Lakeland, FL
Jun 26, 2004
  • Jun 26, 2004
[Sounds of cursing]
Today my uncle offered to install the radiator that I recently purchased for my Stang - He was doing good, until he sheared off the flange that the upper radiator hose mates with on the engine.
Can I buy a replacement for it at AutoZone? If not, what can be done in the meantime?
And if I can buy a replacement, how involved is it to install?
If I cannot buy a replacement, I suppose I'll have to strip a junkyard Stang of it, or, as a last resort, buy it from a dealer.
Thanks...
bhuff30
6,037
35
129
Olathe KS
Jun 26, 2004
  • Jun 26, 2004
the flange? You mean the thermostat housing broke off? If so, yes. it is bolted on with 2 small bolts, and is replacable.
Q
QangMartoq
37
Lakeland, FL
Jun 26, 2004
  • Jun 26, 2004
Bhuff30,
Thanks for the quick reply.
How hard is it to replace, once I have the part to replace it with? I have almost no knowledge of working on the car, and naturaully dread doing it myself, though I'd love to learn sometime. I can do simple stuff like changing the oil, but that's about the extent of my abilities. Hopefully I can bribe a friend with some beer.
JamesBaumann
624
Vancouver Island
Jun 27, 2004
  • Jun 27, 2004
Just a thermostat housing by the sounds of it. It is as simple as undoing bolt 1, undoing bolt 2, replace new thermostat housing into same spot, secure it with bolt 1 and bolt 2. Just take a look. I think when I replaced mine it was about a $20 part. Good luck.
L
latroca1
234
martinsburg,West Virginia
Jun 27, 2004
  • Jun 27, 2004
1/4 inch drive 10 mm socket with a little swivel just follow how you took it off to put back on.
Don't crank the bolts to tight or it will leak on ya. Snug them up and then a little less then a 1/4 turn.
Double check your antifreeze refill if nec. then run it and see if it leaks after it warms up and when you shut her down when she is cooling off.
If succesfull pat thy self on back!!!
D
Question about EGR valve, replacement, and a part on the valve.
  • DPP
  • May 9, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 23, 2026
DPP
D
Help with window and possible engine
  • StefRena22
  • Jun 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2025
Willybill32
M
  • mnky99
  • Sep 5, 2025
mnky99
M
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
E
Finished my Fox Hydroboost Install - Tips
  • Engineer Duane
  • Apr 9, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2025
Engineer Duane
E
