  • 2.3L (N/A & Turbo) Tech
help
  • Thread starter Thread starter cameroonee
  • Start date Start date Jan 1, 2005
C
cameroonee
37
oklahoma
Jan 1, 2005
  • Jan 1, 2005
ok i have a 2.3l out of a 75 pinto that has been built for drag racing it has been ported to the hilt has a cam that is so radical it barely idles it has been bored over .030 with forged pistons. the guy i got it from ran nitrois that is why the cam is insane now i want to put it in a 91 coupe and make it efi i know i need to get a 87-89 wiring harness so i can run a distributer. now i have a set of brown top injectors out of a tcoupe can i use them with a ported lower and gutted upper with a 65mm tb off a 94-95 5.0 if so what computer can i use for this setup and where can i find the wiring harness and computer
W
Willy0314
178
Western Ny
Jan 1, 2005
  • Jan 1, 2005
you might have to go aftermarket, like a F.A.S.T. system or something. im still a little fuzzy on the tuning abilities of these 2.3L computers. You could probobly run a stock computer if you ran a milder cam, but im not sure.
Is in n/a or turbo? or is it still n/a and juiced? Whatever power adder you plan on running will make a big difference in what electronics you want to run.
C
cameroonee
37
oklahoma
Jan 1, 2005
  • Jan 1, 2005
it will be strictly na no chance with turbo because compression is 13 to 1
Stinger
7,754
24
118
Basehor (Kansas City), KS
Jan 1, 2005
  • Jan 1, 2005
Why do you need to run a distributor?
Good luck finding a stock computer that will run that engine worth a crap...why not leave it carbed?
Red_LX
I’m not much help unless you’re looking for ****!
73
129
Morgantown, WV...where couches meet their doom
Jan 1, 2005
  • Jan 1, 2005
Jesus, 13:1 compression? Have fun running that on the street. You're better off leaving it carbed, but my guess is that you'll probably hate driving it on the street anyway.
C
cameroonee
37
oklahoma
Jan 1, 2005
  • Jan 1, 2005
well i was runing a offenhauser dual plan intake with a holley 650 and it was just a pain so i figured i would try efi if i could figure out the computer
Red_LX
73
129
Jan 1, 2005
  • Jan 1, 2005
You'd have to buy an aftermarket standalone system to run a setup like that, those usually cost $500 and up.
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
Door wire harnesses 1996 GT
  • Adizzle843
  • Feb 5, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 17, 2026
Adizzle843
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
