help!!!!!
  • Thread starter Thread starter carbed87
  • Start date Start date Jan 5, 2006
carbed87
215
  • Jan 5, 2006
i know its not a mootang, but i have to rock this until i get out of college, anyways heres the scenerio:
this is only like my third day owning my 1991 trans am 5.7liter. when we first picked it up, we had to jump start it because it haden't been started awhile. but after the drive home it's seemed to be ok. its always taken two-four cranks to start it up, but it always did. well, here's the weird part, today at around 5pm, i was showing it to a friend, and it took like ten cranks, then, when it finally kicked over, it kind of stumbled and died, so i started it again, only i pumped the gas a little, and then it finally started. since then, i've fired it up like three other times, and though i didn't have to use the gas, it still took awhile for it to start.
my question is: could this just be a battery issue, or something else?
when im driving, the volts read around 13.
i know it may sound like somewhat of a newb question, but im just kinda worried. please help, i'd really appreciate it.
thanks, mike
bill302
2,131
alabama,gadsden
Jan 5, 2006
  • Jan 5, 2006
you might just need a tuneup not a bad idea if you just bought it.is the check engine light on? and make sure you replace air and gas filter.
carbed87
215
  • Jan 5, 2006
good idea, no check engine light, but i do know that the cap/plugs/wires/rotor/injectors/coil is brand new. i work at grease monkey so preventative maintenence isn't an issue, just trying to work in a good word with our new owners. whe i cash my check, i'll probably do a fuel filter/oil change/rear diff/fuel system cleaning service.
probably replace the battery too. its kind of sad that i get more replies here than in the actual f-body forums lol.
Black1987Stang
1,422
Jersey Shore
Jan 5, 2006
  • Jan 5, 2006
Ive heard one sympton of long cranking is low fuel pressure. Get a gauge on there and see whats going on. Some engines just always to crank for a while till they start like all the 4.0L Jeep engines for some reason, I always wondered why but everyone ive seen took longer than normal for it to start. I can hear one start from a mile away lol
Euphoric306
905
  • Jan 5, 2006
cuz its a GM fool, pick urself up a ford again
carbed87
215
  • Jan 5, 2006
i wish i could, but i dont see it happening for at least another year or so.
but yeah, fp could be a symptom as well.
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
Engine Another no start after washing engine bay
  • bruno
  • Apr 26, 2026
Fox 5.0 Mustang Tech May 7, 2026
AeroCoupe
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
L
Engine Why won't the motor start if I have spark and fuel
  • LeviAnderson
  • Nov 20, 2025
Fox 5.0 Mustang Tech Nov 20, 2025
AeroCoupe
