  • 2.3L (N/A & Turbo) Tech
Help
  • Thread starter Thread starter Fast_Mustang87
  • Start date Start date Jun 2, 2006
Fast_Mustang87
97
Illinois
Jun 2, 2006
  • Jun 2, 2006
Well ive been having this problem for a while now. Sometimes when u first start the car is idles rough and the rpm go's down to 400. I had a performance exhaust put on and a set of msd coil packs, well me and my dad thought it was the cat converter clogged so we cut it off, well that didn't take care of it. Me and my dad think are timing could be off because we put msd coil packs on the car, so maybe the timing is off? The check engine light comes on and it idles rough and misses. Also but everything is fine after the car is warmed up so we don't get it. Maybe a o2 Sensor? The car is a 1991 L.X 2.3 , any help would be great!
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Jun 2, 2006
  • Jun 2, 2006
Check the codes. If its 223 or 224, it could be the ICM or also the coil packs, but you said you just changed the coil packs. Bet you payed dearly for MSD coil packs The ICM controls the output to the tach. Mine was dropping RPM's and even dying when the Check Engine light came on. If you do a search on ICM you should be able to find my last post and a few others that have had the same problems. Good Luck.
Swarzkopf
973
Pittsburgh
Jun 2, 2006
  • Jun 2, 2006
Yeah, it's probably the ICM. Man, I wouldn't wish another ICM nightmare on anyone after the crap that I just went though.
Fast_Mustang87
97
Illinois
Jun 2, 2006
  • Jun 2, 2006
Alright ill have someone check that out, i did mess with the tach needle when i put my white face gauges, but thanks for the help everyone
M
Help! 2003 GT misfire when hot
  • Modular03
  • Feb 10, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Feb 13, 2026
Mustang5L5
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
M
Engine Unexplainable Exhaust Pop and Gurgle
  • Mrnissen122
  • Feb 14, 2026
Fox 5.0 Mustang Tech Feb 18, 2026
Screamin Demons Worth It N/A?
  • Blackout67
  • Oct 20, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 20, 2025
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
