My car is currently at the gas station so if anyone can help me narrow it down a bit that would be great.
Started it up to go cruising earlier got to the gas station and filled up, tried turning on the car and nothing it would crank and crank checked my fuel pressure guage getting fuel so spark? i stuck a screw driver in one of the plugs and had a friend watch while i cranked it but correct me if im wrong doesnt the screw driver have to be grounded in order to see a spark? well it wasnt grounded so I concluded no spark.
Could the stator be the source of the problem? I only ask because I know its bad it does the bucking/surging thing under 2k, the starter solenoid works because I jumped the postive and negative with the screw driver
any ideas?!
Im almost postive that the problem is the stator/ PIP? if so can i replace it easily without removing the distrubtor from the car? I dont have a timing light to realign it again and its at a gas station
any ideas?!
