help
  • Thread starter Thread starter 95in1984
  • Start date Start date Dec 23, 2006
9
95in1984
  • Dec 23, 2006
i have 1984 mustang with a 2.3 which is long gone been replaced a1995 5.0 wich is carburetor,with a single plane intake,msd distributor. aftermarket cam,with 5 speed.and3.73 gears.the qestion i havehow do i wire the 3g alternator to the volt.regtor,with the original wireing.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Dec 24, 2006
  • Dec 24, 2006
You don't, unless you want to watch the car burn? The 3G is internally regulated also, so you can pitch the original regulator.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Dec 24, 2006
  • Dec 24, 2006
Use a smaller mega fuse - 125-150 amp.
Mustang78
486
Aberdeen, WA
Dec 24, 2006
  • Dec 24, 2006
thanks jrichker, that picture helps a LOT on my 82, i used the stock regulator also, which is probably the wrong way to do it, should i remove my stock regulator?? if i can that would be most excellent
~Mark~
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
  • dan50
  • Jul 18, 2026
dan50
C
Electrical HELP! 1989 5.0 Stick, Voltage Bleed onto Ignition Trigger wire
  • ChickenDeluxe
  • May 14, 2026
Fox 5.0 Mustang Tech May 24, 2026
ChickenDeluxe
C
  • brandyn200
  • Jun 20, 2026
AeroCoupe
