I just picked up my 90 lx and have run into this problem. Ok so i jacked my car up to work on the exhaust...before i jacked it up the shifter bezel went on fine...when we lowered the car the bezel wouldnt clip in right...anyone else have this problem??? i jack it up on the fram rail just like i used to in my capri. could it be the crossmember for the trans bent up?? any help would be great guys i really need it!!
im just about to put my AFR 165's with upgraded valve springs, Fms F303 cam, scorpion 1.7's, air gap intake and 3:55's in an now i ran into this problem which i wanna fix before i put this stuff on. Also, anyone know what kinda power an times i should run with the mods below??
Edelbrock 600cfm carb w/ spacer
Edelbrock Air Gap intake
MSD 6AL & Blaster 2 coil
FMS shorties, off road h and MAC 2.5 inch catback
AFR 165's w/ upgraded valve springs
FMS F303 cam
Scorpion 1.7 roller rockers
FMS 3:55's w/ eaton posi an 31 spline axles
Centerforce dual friction clutch an new flywheel
75-100 shot
FMS F303 cam
75-100 shot
