  • 1994 - 1995 Specific Tech
Help?
  • Thread starter Thread starter cdiehl30
  • Start date Start date Feb 11, 2008
C
cdiehl30
  • Feb 11, 2008
I have a 1995 cobra...So far I have exhaust, and underdrive pullies...I have about $4000 to spend...I am all about speed...what is the smartest thing i can do?
toyman
1,944
54
79
Vernon BC
Feb 11, 2008
  • Feb 11, 2008
Boost and gears
V
viridionplague
98
  • Feb 11, 2008
gears and a kenne bell
or
408 swap and gears,
definatly gears though
HGFireHazard
460
Michigan
Feb 11, 2008
  • Feb 11, 2008
Well, something boost related is definitely the right idea, but the budget might be a little bit tight to do it 'right'.
You could take your pick of forced fed goodness, but you have to remember the supporting mods. Fuel and air flow are the most important, and ignition is in there too, especially with the better factory flow of the cobra over the GT.
Beyond that you should think of your driveline. How long is that drive line going to hold up to boost?
Not to discourage you, of course, but sometimes it's better to make sure you can put the skinny to the floor and not worry in the back of your mind that something is going to break.
ProKiller
3,064
15
78
PA
Feb 12, 2008
  • Feb 12, 2008
i'd also say go with boost. your best bet would be to get a used vortech kit off corral.net or something and put the rest of the money towards supporting hardware like injectors, maf, and tune.
95opal
5 Year Member
Nov 16, 2004
449
20
39
Feb 12, 2008
  • Feb 12, 2008
N
Nagash01WS6
402
Deland, FL
Feb 12, 2008
  • Feb 12, 2008
Suspension.
Sub Frames, Rear Lowers and Uppers.
Gears.
What kind of transmission? If an automatic... converter.
Then a nice set of heads... Trick Flow or Canfields, and a cam and intake to go with them. You MIGHT be able to squeeze in a 347 with those funds...
Regardless, you need suspension.
95CobraMike
1,046
Lima OH
Feb 12, 2008
  • Feb 12, 2008
invest into some sort of mutual fund getting close to or more than 12% return on your money.....
ORRRRRR if you are determined to spend it on your car... id say supercharger!! or if thats not what you are going for... suspension, gears, heads, cam, intake, upgrade the tranny, aluminum driveshaft, new radiator... then next time you got some cash laying around you can do the supercharger and realllly go fast
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
Engine 95 GT and 95 Cobra sensors and TB gasket
  • Sonic
  • Dec 21, 2025
1994 - 1995 Specific Tech Dec 23, 2025
WhiteCobra95
R
Need a little help identifying this plug
  • redlineracing1328
  • Oct 7, 2025
1994 - 1995 Specific Tech Oct 8, 2025
revhead347
R
electrical plug identification
  • redlineracing1328
  • Jun 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 12, 2026
keel
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
