i have a 2006 v6 mustang and i cant get the headlight assembly out i have taken all the bolts out do i have to remove the fender? idk if someone has changed them out please help
You don't have to take the fender off but you do need to remove the front bumper cover. Put the car up on jackstands. Working under the car remove the fasteners securing the lower edge of the bumper cover. In the front wheel opening remove the retaining screws securing the bumper cover to the inner fenderwell splash shield. pry out lower edge of splash shield, reach up behind the bumper cover and remove the bumper cover to fender retaining screws and remove from car. Remove the upper headlight housing mounting bolts and pushpin. Remove the lower headlight housing bolts. Pull out the headlight housing assembly and disconnect the electrical connector.
