help
panther007
i bought a 1995 gts noticed it had a slight miss at low rpms.header pipe #6 wasnt as hot at start up as the rest.checked and replaced plugs. wires. same problem.cruising at a constant speed the car humps.took the plug out of #6 and car runs the same.was told maybe an injector bad.replaced them also .no luck! removed the heads and #6 valves are wet and the same color
Was there spark?
Was the injector exciting (was there constant 12V and modulate ground to energize the injector)?
The injector might have been leaking. The gas (solvent) could clean the carbon off the piston while the car sat.
