Engine Help
  • Thread starter Thread starter roworld
  • Start date Start date Jun 11, 2014
roworld
105
baltimore md
Jun 11, 2014
  • Jun 11, 2014
I have a 88 gt it has a 306 bottom with gt40p heads ,bbk shorty headers, bbk ssi intake, and bbk 70mm tb. About 2 weeks ago I started having problems with the idle. It would surge then die. I thought it was due to the lack of fuel so I installed a set of 24lb injectors from a mark viii and a c&l 73mm mas air with the blue sample tube. I also found and replaced a bad plug wire on my #7 plug. I checked the codes and my scan tool said I have a bad o2 sensor. I replaced the one on the passenger side because I wired a rich lean gauge to it just a few days before the problem started. I rechecked the codes and it was ok. I also checked for a vacuum leak and replaced my map sensor, mas air sensor, and coolant temp sensor. now the car idles at 2000 rpms. And my headers get red hot where they connect to my h pipe. Im lost please help.
roworld
105
baltimore md
Jun 11, 2014
  • Jun 11, 2014
I forgot to add I also have a msd 6al box.
stykthyn
5,232
2,652
223
gainesville
Jun 11, 2014
  • Jun 11, 2014
http://forums.stangnet.com/showthread.php?t=698148
This thread is worth its weight. Go through all the steps
mikestang63
SN Certified Technician
Aug 27, 2012
11,606
8,859
214
In the garage
Jun 11, 2014
  • Jun 11, 2014
Run the codes before you chase any more dead ends.
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
L
Electrical problems with passenger side downstream o2 sensor
  • Lexiii12
  • Sep 14, 2026
2005 - 2014 S-197 Mustang -General/Talk- Sep 14, 2026
Lexiii12
L
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
