  • SN95 4.6L Mustang Tech
HELPP PLEASE:(
  • Thread starter Thread starter 2002GtRed
  • Start date Start date Aug 24, 2011
How to fix it
  • Fuel injectors?
    Votes: 0 0.0%
  • Spark plugs?
    Votes: 0 0.0%
  • Total voters
  • Poll closed Aug 27, 2011.
2002GtRed
9
  • Aug 24, 2011
My service engine service light came on and ran the code and said that i am running to leani cleaned the maf sensor and bought some lucas fuel injector cleaner. What do you guys recommend i should do any help would be very appreciated.
Rick 91GT
Mustang Master
95
99
PA
Aug 24, 2011
  • Aug 24, 2011
Watch how much Lucus you add it will lean it out more. What code did it throw?
trinity_gt
3,125
81
99
Canada
Aug 24, 2011
  • Aug 24, 2011
What was the code?
O2 sensors are wear/maintenance items. It's probably just time to replace one or both. The code should be able to tell you exactly which one it is.
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Aug 24, 2011
  • Aug 24, 2011
Vote: neither. Vacuum leak.
Spark plugs aren't likely to cause a lean condition.
If you really want to clean the fuel injectors, consider an injector cleaning/flow test service such as injectorrx.com.
Go back and rule out a vacuum or exhaust leak. Your wallet with thank you.
OBTW, always post the full codes.
As Trinty-gt said, the O2 sensors do wear out. Consider replacing if over 100k miles.
Jhunter
68
  • Aug 25, 2011
neither possibly 02 sensor misreading.
N8Dogg98
3,872
238
184
MN
Aug 25, 2011
  • Aug 25, 2011
I had the lean codes in both banks as well after I installed my cams. When I popped the hood I realized that like a retard, I forgot to hook up the tube from the upper plenum to the air intake. Once I hooked it back up and cleared the codes, it was fine.
Burns is right. It's most likely a vacuum leak somewhere and is likely a "free" fix.
GTMUSTANG2000
  • Sep 1, 2011
with most fords, a lean bank 1 & 2 code is a vacuum leak, seems like from about 1997 to 2004, ford used some pretty crappy vacuum lines, we replace vacuum lines on ford trucks all the time when lean codes are present.
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
  • Gulftown980x
  • Jul 29, 2026
squeak93
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
